boost gauge install problem
91gsdohc
1,099
Jan 25, 2010
around, Connecticut
i have read up on a couple forums and vfaq and i still cant seem to find out where to T the gauge and what T to get. all the fourms ive read i think there for the 2G because i cannot find what they are point out. so if you direct me or show me where i cant T the gauge that would be helpful, also where i can pick up the T because i went to autozone and could not find one that would fit the boost gauge house. thank you for your time
T into the vacuum line between the intake manifold and the fuel pressure regulator.
Here is a Tech Article: http://www.dsmtuners.com/forums/articles-turbo-system-intercooler/205099-boost-gauge-install-where-tap-source.html
And here are 11 pages you can flip though if you need more info: http://www.dsmtuners.com/forums/appearance-interior-exterior/15966-how-do-i-install-boost-gauge-gage-guage-1g-2g-merged-8.html
That's the line I tapped into for my Boost Gauge. Only problem it seems bigger until you cut it, It's very small inside haha! had little trouble putting on my T but once I got it on it's solid!:thumb: - Ryann :talon:
what size T did you use and where did you get it
thats the line i cant find/see
what size to all i could find is 5/8
I'll make this very simple for you. Here is a picture I just took off of my 1g. T into the line that runs from the intake manifold to the fuel pressure regulator. I used a 4mm vacuum line which is comparable to 5/32".
is the house behind the fuel rail? if not can i get a picture thats not close up, because im looking expecting to see it plain as day but im not, but if its hiding behind the fuel rail then i found it
alight i guess everybody else has more room to see in there cars then i do? because mine is not open that big, but i know the house thank you
To be hoesnt I for got! The Gauge came with the whole kit. I have the AutoMeter Ultra Lite Mechanical Boost Gauge.
i bought a use gauge the i got a install kit and theres no T in there
Well it's not a install kit, My gauge came with everything I needed to install in.
I hope this helps! This is where I tapped into mine! - Ryann :talon:
What is this house that you are looking for? Do you mean hose as in vacuum line? :sneaky: ROFL ROFL ROFL ROFL
Also I don't understand how you don't see the vacuum line in that picture. I'm not hiding it, I promise.
haha dam my bad i didnt even realize i was typing house but yea hose and please no more pictures of 2gs thats just confusing me more then what i am already, anyway heres some pictures of the HOSE i am assuming it is untill i saw the other picture sik95 posted that just confused me and what confused me in other post i read.
IS THIS THE HOSE
<a href="http://www.flickr.com/photos/50529416@N08/5586108341/" title="IMG00115-20110403-1709.jpg by letsgetwasted, on Flickr"><img src="http://farm6.static.flickr.com/5102/5586108341_c829beba2a.jpg" width="500" height="375" alt="IMG00115-20110403-1709.jpg"></a>
<a href="http://www.flickr.com/photos/50529416@N08/5586703262/" title="IMG00113-20110403-1708.jpg by letsgetwasted, on Flickr"><img src="http://farm6.static.flickr.com/5255/5586703262_aa1e7d76d2.jpg" width="500" height="375" alt="IMG00113-20110403-1708.jpg"></a>
<a href="http://www.flickr.com/photos/50529416@N08/5586706700/" title="IMG00114-20110403-1709.jpg by letsgetwasted, on Flickr"><img src="http://farm6.static.flickr.com/5097/5586706700_fec80f2e6d.jpg" width="500" height="375" alt="IMG00114-20110403-1709.jpg"></a>
this is what i see when i am looking at the engine witch is why the 2g pics confuse me and why i said it looks like i have less room then everybody else
<a href="http://www.flickr.com/photos/50529416@N08/5586203079/" title="IMG00116-20110403-1730.jpg by letsgetwasted, on Flickr"><img src="http://farm6.static.flickr.com/5148/5586203079_19c6bda79d.jpg" width="500" height="373" alt="IMG00116-20110403-1730.jpg"></a>
Yes that is the line. I'm sorry, I guess my 1g isn't a good example as its not exactly stock anymore. I eliminated that solenoid pack there, all those vacuum lines, my cruise control, a lot of the wiring harness, and I moved the coil pack. That's why there is more room in my picture. That is the line you want to tap though.
alright man thank you.. but at least you know why i was confused with everybody's pictures but alright thought so just wanted to make sure
so know i just need to find a T that will fit that, i bought a pack of 3 or four brass Ts and none of them are small enough so can i ask where you got yours (i went to autozone)
Well I got mine from a friend who ordered a bunch from McMaster-Carr because its threaded on one side. I'm sure you could get a regular vacuum line T at auto zone though. They are plastic, not brass.
i only got the brass because i wasnt sure of the size and there was a couple in there, the only other one was a rubber T and it looked to big.
i knew the hose i needed to use i just couldnt find it that good.. and if im going to do something im going to do it right.
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
  • For sale 4G63 Griffin intercooler cores
    Griffin intercooler cores. Top to bottom flow. High cfm and heat transfer. 24x8x2.75 and...
