boost controller questions
tips000
277
Feb 22, 2011
kalkaska, Michigan
my car has a manual boost controller and i was wondering with stock components except a 16g and a new BOV and intake, how much boost should i be able to push? what is the limiting factor?
You can increase boost until you knock, go lean, or hit fuel cut - whichever comes first.
If you don't have a way to monitor those things, you can't increase it at all. 10 PSI is actually less than stock, so you should be fine if you can even get it that low.
ok i am running 10 now, just wanted to make sure i wasnt over doing it or being too much of a pansy.
thanks
First of all stock is 14-15 PSI so if your running 10 your way below stock. I would leave it at 14PSI and go from there! I'm running 16PSI and my car is running fine! I have WideBand though!:thumb: - Ryann :talon:
