Bolt size help
SaskTSI
54
4
Aug 17, 2019
St. Brieux, SK, Canada
Hey everyone I need to know what size the 4 bolts are that hold the exhaust to the turbo housing, not the manifold bolts. Thanks
(Dont know If it matters but I have a big 16g)
If you're looking for 02 housing to turbo, they're 14mm m10 x 1.25 31mm long. I used a stud and nut for the hard to reach one.
Where by chance did you find them?
Also would there be any power loss or harm in driving the car with it leaking from there?
I mean its not a small leak
Pic would be nice.
If it’s your daily, just don’t get on it. I had a two hour drive when my wastegate broke off my manifold on my 2g a long time ago. Weld literally broke off completely. Cruise and idle was fine.
Pic would be nice.
It's my daily and it runs fine when I'm on it its just a loud leak you can hear
You might get more power actually but I personally never push my cars when something is off. I don’t think you’ll hurt anything but again, your o2 readings will be off so bad fuel economy is probably the worst case scenario
It shouldn't be that hard to fit new gasket and bolts if all the old ones come apart OK. Exhaust fasteners are notorious for twisting in half, making a routing job a much more serious affair. Pre-soak liberally with some quality break-free penetrant, and sometimes the use of a propane torch can be effective.
That jobs already done for me haha waiting on the new gasket but the bolts are spitting themselves out
Did you torque them? Hard to do on the car and the one bolt is impossible. Clean the threads on the housing.
Also check the flatness. Most likely they're warped. If so, remove both, put sandpaper on a flat surface and go to work.
The 2 left in there are staying tight after I tightened them down, couldnt get a torq wrench in there so i just tightened as much as possible, but they were spitting out before then hence why i only have 2 bolts
