Bolt and stud sizes?
Cynxe
263
6
Feb 19, 2015
Ottumwa, Iowa
What are the bolt sizes for 1990 talon tsi?
Trans bell housing
Starter bolts
Where driveshaft connects to differential
Exhaust manifold
Please help. My car came as a project and i need these to get it done.
I believe this is the only one of those that isn't in the threads linked for you. You can find out its size here: OEM Part Number
It doesn't seem to have the bolt size for the driveshaft where it connects to the rear diff
The 1G article "is a compilation of most of the bolts, nuts, screws, or fasteners that are found in the 1G, 2.0L engine bay..." That's why. :)
Well, i feel like the trans bolts are longer than 40mm. Is it a sure thing that they're only 40mm?? M10 x 1.25 x 40mm
For my own information, since I assume you referenced the 1G bolt thread linked above for that, what made you assume that there was only a single bolt listed for the transmission to engine mounting bolts? Is there something that could be done differently with the format you might suggest? PM me if necessary.
Only one of the transmission bolts is 40mm long. One is 43.5mm, one is 65mm, and the bolt that goes through the rear ear on the engine block and threads into the transmission is a M8 x 1.25mm x 60mm long.
