bogging and sputtering please help !
kriscameron
Sep 19, 2006
garland, Texas
ive searched the forum and tried everything i can find.
i have checked for boost leak
the isc tested good
the tps tested good
ive changed the cas with another one from a running car
new knock sensor
new fuel filter
new plugs and wires (twice on the plugs)
whats really strange is sometimes it just starts running fine and pulls really well then 10 minutes later it starts bogging again and when it bogs the boost guage goes up to like 12 and it just bogs down and spits and sputters
please help
the isc tested good
the tps tested good
new knock sensor
new fuel filter
please help
Pull the ecu and check for leaking capacitors and/or board damage.
sorry to for this stupid question but this is my first dsm
where is the ecu on this car ??? 91 eagle talon
i dont see any leaking or damage
any other ideas
im looking for a way to test the fuel pressure and test the maf sensor if anyone has links to this info please post it
Do you or a friend have a logger . That would show you error codes . You do not always get a cel when there is a problem .
i still have nor resolved this issue. today i replaced thr throttle body with a working ics and tps. changed plugs and put in a new o2 sensor. still same problem. is there any way to actuallt test the maf????????
any other ideas
To test fuel pressure you will need to tap into the supply line. There is a hard to find dealer tool that can be used but Haynes manual shows how to fab one that fits the banjo fitting on the fuel filter outlet. You should also test the fuel pressure regulator.
ok this mornig i pulled out the new plugs and o2 sensor all were covered in thick carbon. i guess this means i m running rich right??
i also noticed that when i unplug the maf it runs better it stull studders a bit but will rev bast 3k
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
  • Wanted GVR4 3000gt vr-4 gen 1
    Looking for a 1st generation vr4, preferably 1993 due to the 25 spline output.
    • Pressterra
