Blue Gasket Maker for my VC Gasket.
j_eclipse96
175
Oct 26, 2004
Laramie, Wyoming
I know what you're all thinking, no I am not asking if this would work, I am posting because this has already been done. :notgood:
My engine had a rebuild about 23k ago, and I noticed the other day that theres that blue "gasket maker" crap in the VC crevice, where the VC gasket should be. This worries me. I didn't own the car when it got rebuilt, so I did not know how the rebuilt went. But if he was too cheap to buy a new VC gasket, maybe he cut corners on engine internals too? :|
I also saw that my TB gasket was broken, and sealed up with silicone. My engine is leaking oil, but that is because I have ancient VC bolts, but I just ordered new ones. Should I clean the engine after installing the new bolts, and see if it still leaks? Or just open up the VC and replace the gasket?
I've had bad experiences with that blue stuff in the past, Whats your guys' take on this? Thanks.
(The blue also looks kind of ridiculous with my red-themed engine bay, but thats not really important)
Are you sure there is no gasket in there. A common method is to use liguid gasket to aid in the sealing of the corners of the gasket. like say in the corners where the gaskets go over the cams.
My new VC bolts should get here any day, I'm going to check the gasket then. And yes, Defiant, I realize the importance of this, and if the gasket is bad I will replace it. I forgot to mention in my first post I haven't taken off my VC yet and looked to see if a gasket is even there. :dsm:
  • Wanted 1g Looking for pn MB522081
    Looking for a factory 1g double din radio bezel pn MB522081
    • Kgilis
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
