Drvlikeustoleit
- 0
- Dec 2, 2008
Belfry,
Montana
As the title says i lost my headgasket, and im comng to find it hasnt been alot of fun. After a few weeks of working on the car for a few hours a day i finally got the head off. I had coolant sitting on top the #3 cylinder as expected, put upon looking at my actual gasket the results kind of suprised me. There is definitly a hole in the gasket and it looks old and worn down, but when i blew it up i had tons and tons of white smoke. Im wondering if this little hole...say maybe an 1/8th inch big could cause all that smoke?
So as i wait for my gasket set to arrive im starting to think of all the things ive done wrong in the removal process...first off i took the cams out, but i did mark their position very carefully, so in know exactly how the cams were set with the motor sitting as it is now. I never did set the motor at TDC howeve because i didnt realize you needed to.
So now the timing belt is still in there, around the pulleys and tensioners behind the bi*** of a cover i cant get off. The only missing link is the cam gears that i took off with the cams. When i do get my new gasket can i just put everthing back together the way it was before or how should i go about doing things?
Also is there a special procedure when putting the gasket on? Should i clean the block beforehand because it has some kind of wax looking material all over it..im assuming from the previous gasket?
sorry this is so long and may not make much sense but i need some advive as soon as possible. thanks in advance you guys.
