Blown engine?
techghost
196
Feb 8, 2009
Karachi, Asia
Today i noticed that if i block the valve cover outlets (i dont have a one way valve on the one which goes into the intake manifold, its open) some air builds up in 30/40 seconds. i have both vented to atmosphere/open.
I also changed my plugs and had a look inside to see piston, 2/3 were on top and it seems to me that they were a bit shiny (like they have a layer of oil or something) but there was no sign of oil on my plugs and car ran ok as well.
Is it normal?
it was a normal procedure, i wanted to change my plugs and therefore had a deep look in it.
car idles fine just a few misfire but rest is ok, vaccum is 19/20hg as well and boost is good. when taken out plugs were perfect not soaked at all
I'm running 24psi on a holset hx35 7blade billet wheel with 12cm2 housing. my car dosent blow off the dip stick neither reduces oil nor any sign of smoke on idle/drive/boost what so ever.
Let me know if having the air trapped in the tappet cover is normal?
