blown engine?????
josedll
38
Aug 28, 2005
amarillo, Texas
well i go to school and i finally got the chance to come back home to fix my car(blow turbo).
the installation was good and fast. the problem happen when i started putting coolant on. i heard i small leak thinking i had forgotten to connect a coolant line i when down to find out that the coolant was coming out off the rear of the engine. not been able to see i squeezed my camera in there and took some pics. can someone let me know if this is fixable or do i need a new block.
if the block is useless or can it be resused, because if t is useless. i will have to tow the car to my job(mitsu dealer)
well my turbo was leaking coolant as well but when i removed the turbo i drain all the coolant(stupid of me).
If it is coming from the rested area it can be fixed but it will be a temp fix and permenate fix. It has a crack which will cause some over heating here soon. You might can get away with some JB weld but its all up to you.
ok what can i do can i only get the freeze plug and install it. will this fix the problem
thanks to everyone helping. i will take the car to my job were i will probably rebuilt the bottom since i think it is time for A new timing belt (68,000 miles).
How long have you had the car? Every time I have ever saw a missing freeze plug like that, it has been due to having straight water in the car and it freezing up. But I also saw that you live in Long Beach so it kind of rules that out unless you bought it like that. If it pushed out from freezing, I would do a compression test to make sure that nothing was cracked from the freezing. If it checks out just put a little bit of jb weld on the new freeze plug and tap it in. Make sure you check the motor for any other leaks when you fill it up.
