Blow thru with no SAFC
killinlonelinez
May 11, 2008
Midway Park, North Carolina
:confused:Now i see evry1 doin it but the question is are you going to need to ue something like the SAFC with a blo-thru if you are only using your stock injectors?
ok because i plan gettingthe whole maf/maft setup with a walbro pump but didnt know if the safc was completely necesarry. i will be runnin a evo 16g within the next 3 weeks so the injector upgrade would be needed right?
As stated already it is not necessary to get the S-AFC. However the S-AFC is more accurate than tuning with a MAF-T. Also there are more people on here that tune with the S-AFC so you will be able to get more help (or if you went to a shop to get it tuned most shops can tune an S-AFC but probably not a MAF-T). But it's up to you and if you want to install it and spend the extra money.
Why dont you wait a little bit and save money for DSM Link , its better than the SAFC and in the meanwhile tune the injectors with the MAF-T.
