Blow thru set up with no maft
93DE-EZ-UM
57
Mar 24, 2003
Raleigh, North Carolina
I have ordered the Dejontool blow thru setup but don't have the money to get the maft right now. Will there be any downfall on installing this without the maft for now and just put the 3" PCV pipe in place of the maft? Just a little impatience.. :D
Yes, I'm still running stock mass. Thank you all for replying. I tried to find the long 3" connector rubber clamp for Homedepot and couldn't find any long enough. But then again, I just don't know of how long of a gap i have to fill and don't know how much pressure can these rubber connector hold without the pvc in the middle and 14 psi of boost. I just gonna install th uicp and see how much gap I have to fill the go from there.
Thanks everyone.. :thumb:
About a 9 or 10" piece of hose should be enough if I remember correctly. Also the rubber stuff from Home Depot is crap. I tried to use the reducer for a couple of days on my Dejon Tool pipe to Alamo IC, it worked good til I drove the car. The hose warmed up and the pressure busted it. I dont know about your area but here there is a Volvo truck shop that sells 3" radiator hose for semi trucks. That stuff is hard and tough and would do the job. Infact, my friend uses that as the main section for his lower intercooler pipe to his Supra Side Mount.
EDIT** Forgot to mention the stuff I'm refering to they only sell it in 3' sections, so its about $30. Best of luck
