blow by , blow thru
nicknorth11
663
7
Feb 9, 2005
Grand Blanc, Michigan
I have had issues with this in the past, but changed my pcv and it was fixed. Now, though, I am having problems with it again and my pcv is fine. My compression isn't the best, but the cylinders are around 180, 165, 155, 175. I know the 155 one is a bit low, but I'm pretty sure I've read that if the numbers are within 15% of eachother, the rings are probably fine, and they are right around 15%. Also, I have never had any smoking issues, which is a sign of rings.
So, does anyone have any advice for me, or any ideas to try?
Thanks in advance
Then it's probably not blow by, more like turbo seal, pcv, valve seals and then maybe rings but not likely.
I also blow a LOT of oil out of the dipstick when boosting at 20 psi or higher.
1. Repeat the compression test and immediately follow it up with a wet test, make sure the car is fully warmed up.
2. Is your crankcase ventilation properly re-routed? As in pcv to IM and breather to intake pipe?
I did the compression test as you mentioned before, but I don't remember the results. I'll try to do it again soon.
The crankcase ventilation was properly routed until this morning, but I put a breather filter on my catch can and removed the hose connecting it to the intake pipe so it would breathe better and not cause me to lose 1/2 quart of oil, as it did last night.
  • Wanted 6 bolt NT water pipe
    • chrisman287
