Blow Off Sound ?
turbotsi90
96
Mar 4, 2008
Salem, Oregon
Just curious if my car is supposed to make any kind of sound like that. I'm still using the stock 1g maf and stock BOV but when I get on it any I can here what sounds to be swoosh sound? Its not real loud but it is noticeable .
Thanks
With the stock setup, you'll be able to hear the turbo spooling a little bit, then almost a 'sighing' sound when the BOV opens.
The sounds will be more pronounced if you were using a metal intake pipe, and once you begin to up the boost a little as well. Some of the things to make the sound more noticeable for the time being are:
-Hack the aircan.
-Use a K&N OEM replacement air filter instead of a paper filter.
-Remove the silencer from the MAS. This will do nothing to hurt the car's performance.
By the way, that's a clean '90 you have there.
-Hack the aircan.
thank you
