black spacer
68442
639
5
Oct 14, 2007
Des Moines, Iowa
What is this? Its from the intake area, I can't find it in haynes or the fsm. thanks
when i took my rail these also fell off but i can only find two of them. thus i put those on the ends. is this ok? do need another one in the middle in order to run correctly?
You should get the third for the middle so you can securely tighten all the injectors down. You may get boost leaks around the injectors without it.
