Big T28 Guys With 550's And Safc... I Could Use Some Advice.
hottboost
273
May 17, 2006
Romney, West Virginia
Started Tuning This Evening With The Safc. My Lo Settings Are -5 Across The Board. Im Logging With Palm-n-stien. The Fuel Trims Are Staying At 0 So I Think Im Good There. Now My Hi Settings Im Started Base At -14 And It Seems To Be Running Pig Rich. I Realize These Are With Narrowband O2 But Befor It Was Staying Around 0.96-0.97 All The Way Across. Curious As To What Settings Others Are Running... And I Know Every Car Will Be Different!!
Rpms O2 Timing
2940 0.91 17
3088 0.93 12
3256 0.95 10
3464 0.97 8
3672 0.97 7
3896 0.97 9
4088 0.97 10
4300 1.00 10
4484 1.00 10
4668 1.00 10
4872 1.00 11
5032 1.00 11
5132 1.00 12
5308 1.00 13
5484 1.00 13
5588 1.00 14
5704 1.00 15
5844 1.00 15
5924 1.00 16
6008 0.97 18
6192 1.00 18
Had To Stop Because I Saw Headlights. Trying To Be Safe! Please Thanks In Advance
Read this - http://www.dsmtuners.com/forums/showthread.php?t=58403
450/550 - 1 = - 0.18181818.... or -18%
To be on the safe side, have your low and high settings at -10 across the board and tune from there ( @10psi settings).
Rpms O2 Timing
2940 0.91 17
3088 0.93 12
3256 0.95 10
3464 0.97 8
3672 0.97 7
3896 0.97 9
4088 0.97 10
4300 1.00 10
4484 1.00 10
4668 1.00 10
4872 1.00 11
5032 1.00 11
5132 1.00 12
5308 1.00 13
5484 1.00 13
5588 1.00 14
5704 1.00 15
5844 1.00 15
5924 1.00 16
6008 0.97 18
6192 1.00 18
Had To Stop Because I Saw Headlights. Trying To Be Safe! Please Thanks In Advance[/QUOTE]
alright im gonna try to pull some more logs today. I did notice that as I was leaning out the top of the hi settings it was starting to run better. Also Wimploki I printed that thread befor I started and throughly read it. also used rre's page. Thanks guts
Dont have my loger with me. Im slowly getting it there. Right now Im at -19 on the Hi TH from 5000-7000rpms. Seems to pull good and timing curve is good along with EGT'S. Now I just need to get the 3000-5000 range and Im in business. Thanks for the help. Im tuning it at 21PSi. I did about 6 hard pulls the other evening when it was humid 85* F! The stock smic was still cool enough to touch so I think Im good there?
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
