Big Problems need help 1g dsm
Norcalrallyist
149
Dec 4, 2003
My car started leaking oil from the valve cover gasket area about a week ago and I thought it was just bad gasket but I noticed it was actually being pushed out between the valve cover and gasket. So I was driving on the road today and suddenly I lost power. It was running on 3 cyl. I drove it to a gas station and now the leak had become a lot worse. I got it towed home and number 4 has no compresiion. All 4 plugs looked good. I thought that I had a valve seal that was causing me to burn oil once in a while. If that seal is in really bad shape am I losing all my compression through the valves causing that pressure in the valve cover pushing the oil out?
bad head gasket or burnt valve or bad pcv valve.are you blowing the dipstick out?A bad head gasket would make it over heat but there is always that different situation and you might be the lucky one.Do you have water in the oil or vice versa?
no im not blowing the dipstick and theres no water in oil. I was driving along normal temps and it just dropped a cyl.
Some picture's would definatly help on this. Sounds like a burnt valve to me too but it could be that the rings in that pistons are shot for some reason or something like that but I bet you burnt a valve and need a new one.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
