98autogstspyder
- 297
- 9
- Apr 1, 2003
92 Talon Tsi AWD,
Florida
I have devoted about 2 hours tonight reading and searching on info on the big brake upgrade for our cars. The vehicle I am upgrading is my '92 Talon Tsi Awd. It came with the single piston calipers and smaller rotors. Anyhow, I went to vfaq and read the info page on what donor cars have the upgraded big brakes on them. I went to my job (Advanced Auto Parts) and started searching to be sure. I found out that the part numbers on a '93 Talon Awd and a '93 3000gt SL are different. I had read that these cars both had the parts I could use interchangeably. Can anyone explain this?
To anyone that had done this upgrade:
What donor car did you chose?
Where did you find the brackets for the calipers?
Will an "upgrade" drilled and slotted rotor for the donor car from an
aftermarket vendor work to get a little bit more performance from the swap?
Thanks,
Tyler
P.s. Like I said I searched around alot and I am a bit confused mainly by the fact that the part numbers didnt match up on vehicles that supposedly had the same brakes.
Thanks,
Tyler
