big brake upgrade question
crazyboost
219
4
Sep 23, 2003
I can get a pretty sweet deal on a 2g brake setup to upgrade from my tiny 92 rotors and single piston calibers. There is only one problem the 2g setup has the banjo bolt instead of the normal threaded fitting. The guy says he will include some 2g lines but will those work for me or not? What are some other options that will make it work for my 1g?
Correct. To use the 2nd gen awd calipers on a 1st gen you just need the 2nd gen front lines. All 2nd gens use the same front lines.
I just read somewhere that 2g brake lines would not fit my 1g without some extra parts. Has anyone else adapted 2g calibers and lines to their 1g? thanks guys
So the guy said he will give me his lines off of the gsx. Will they bolt on to my 1g without any problems? Or is there some special SS lines i can buy somewhere? thanks in advance
As that link pointed out, if you buy a set of N/A stealth brakes from say a 1991; the calipers will use the screw in style line like you have. I am currently working with a set of those now but mine is a 2g.
If you would rather go with a single brake line on all 4 corners you can get custom lines from ANPlumbling.com. Your hard brake line thread is a 10mmX1.0, sam with the screw in fitting and you can get the lines in lengths from 6" to 46" for an average of 20.00 per line.
I have not personally compared the 1g lines and 2g lines but to my understanding the 1g lines are much longer, the reason for the 8 line kit.
Hope this helps
Terry
