big 16g
white90gsx
674
Dec 21, 2006
Wilburton, Pennsylvania
can i get 11s with a big 16g turbo with injectors
could you give me a list i allready have the afc controller ,walbro 255 ,2600 clutch, fmic what else would i need
Ok think of everything you can do and run lots of boost on a 16g to get into the 11's. Research and see what you need. If you wanting to go that fast I would get rid of the AFC and get DSMlink. AFPR to go along with that 255lph. Full exhaust, cams, methane injection. You need to research a lot more.
ok thanks for the help but were can i get the dsmlink
yea man thanks but this is the first time i ever heard of dsmlink and every person i ask gives me different answers so i dont know what to belive so i have to ask
You could go to the timeslips area on this forum and see what people in the 11's with 16g's have on their setup.
running 11's with a 16g + injectors = no problem
waking up before you cross the finish line = problem
I had an awd, with 190 b16g, 680's, safc and a some other small odds and ends and cut a low 12 with a 75 shot. Maybe not what you want to hear but it was cheap.
major weight reduction will help for this goal, I probably wouldn't daily drive the creation you would make! :)
