2G Big 16G 1G head swap 2G bottom Stock injectors......
rangerguy
162
4
Dec 10, 2002
Newport, North Carolina
I searched and I think I got my answer, but would like a little confirmation.
Assuming the set up above....with a downpipe, exhaust, and stock intake with a
recirculated BOV......and boost controlled by the BCS (stock afaik).
Will I be able to drive the car AND BOOST assuming I use common sense and
don't run the hell out of it. I have some 550s but will have to tune them
at a later point when I get the cable for ECU flash.
Thanks!
You would be "ok" running stock boost levels with stock injectors until you get something to tune with. You should REALLY consider getting a wideband as well.
I didnt mention that, but I do have a wideband as well, an AEM.
I dont plan to rape it, Im aware the injectors are/will be at a high duty cycle and I wont be keeping it this way. Basically to get into SOME boost and work all the bugs out. Thanks!
