XC92
5+ Year Contributor
- 1,654
- 376
- Jul 22, 2020
Queens,
New York
I rebuilt the manual trans on my '92 Talon TSi AWD a couple of years ago and although it's been working just fine as a trans it does have a very slight leak, likely between the mating surfaces of the 4 case sections because I probably didn't use the right RTV (Ultra Gray, probably should have used Black which is more oil resistant) and/or didn't apply and cure it properly (apply, mate, finget-tighten bolts, torque down after an hour, wait 24 hours to refill with oil).
I drained the oil and took off the end part of the case, the one furthest to the right or passenger side, with the trans still on the car, yesterday, cleaned off the mating surfaces and then applied Ultra Black and cured it the right way. But I suspect that the leak is also coming from the other mating surface interfaces, so I'm probably going to have to drop the trans and take it apart to seal all the interfaces properly.
But it's getting to be just too cold here to do that as I work on the car outside, not having a garage or indoor work area. So I'm going to have to put it off till the spring. In the meantime I do need to drive the car. So, I'm wondering if there's anything I can apply to the other 2 case interfaces to temporarily seal them to the extent possible until then, something like RTV, weatherstrip adhesive, Gorilla tape, Flex-Seal, etc. I won't be taking any extended road trips, just local drives of 10-30 miles every few days, in cold weather.
