best spot to run aem wideband thorough firewall?
Unless your putting it in the o2 housing, just run it through the floor.
I have mine run underneath the center console, then under the driver's seat, and through one of the drain plugs in the floor board. I just cut a notch out of the plug, then sealed it up with some RTV silicone.
Attached the wire to the bottom of the car with cable brackets and self tapping sheet metal screws.
