Best injectors to run with 16g
My friends fwd is tuned at 20 psi, on stock 450 cc injectors, on a ported B16g. it just depends on your goals. His makes really good power, he got a guy that tunes everyones cars around me to tune it.
Wow I run 750cc on a 60 trim turbo 23psi 93 octane gas. As stated the largest you can get is always the best.
When I was on pump gas with my e316g I ran 660's with fuel pressure at 43.5 psi and a good amount of 50/50 methanol-water thrown in. Injector duty cycles were about 85-90%. I'm now running e85 and the 660's way too small. I currently have FIC1100 high z injectors at about 70-75% IDC with fuel pressure lowered back down to 1g standard of 37 psi.
I would suggest at least 750's for pump gas and 1000's or a bit larger for e85. You'll need at least a 190lph fuel pump and some way of tuning/compensating for the larger-than-stock injectors. I use ecmlink.
i have been asking almost the same question and have gotten that to run 28ish psi i should be looking at 850-1000 injectors
I also need to know what injectors to run. I am told the car has 560cc but I haven't looked. I just ordered DSMLink. I have a 2.3 6 bolt, with a 16g. I was thinking somewhere in the neighborhood of 880's?
