Bep Hotside Suggestions
RocCitySlayer
792
7
Nov 20, 2011
Rochester, New York
What .ar hotside would be the best for my setup? Mods in profile.
Its a DD street car with an occasional track run. I have a hx35 so I dont really want to lose to much spool time
His profile says he already has the bolt on housing.. your next best bet would be an open T3 .70 or divided T3 housings. On my S200sx-59 the difference in spool was negligible. The power increase was well worth it, especially on the stock BorgWarner T4 housings.
What are your goals for the car, how do you drive it.. where do you want the power?
You have a medium-large frame turbo, take advantage of it. If you wanted insta-spool you shouldve stuck with a 16G.
Personally, I would use a Stock Holset divided housing. 12cm2 or the larger one if you are looking to max out that wheel.
