Turbo hotside
dsmotors95
93
Jun 16, 2012
spring valley, California
Ok so im wondering if i can use this hotside in place of my pte because i cant run the pte for external wastegate. The one where the wheel fits snug is the pte.
^^^ agreed, won't be efficient and will dramatically increase lag. I've done it before back in the day due to needing to get my car up and running for smog. Threw the parts together and viola a 14b that hit 18psi at like 4500rpms... pathetic!
Dont do it, you will be disappointed!
Why can't you run external? Are you trying to run it off the manifold? Looks like it's already setup for an o2 external
I cant run external off the o2 housing because theres a gap between the wastegate port and exhaust port, If that makes sense and the boost falls right into the exhaust. I'll post a better pic of it.
Heres another pic of the pte o2 housing. As you can see theres nothing dividing the boost side and exhaust side. So when boost tries to go to the external wastegate it goes into the exhaust and i build 0 boost.
Ahh, I see now and that makes sense. I would do what archer said and weld the hole shut. It would be cheaper than buying a new hotside unless you come across a good deal
