Resolved belt size for altenator an water pump and other belt ac ,power steering
o0GuitarKid0o
1,077
178
Dec 12, 2013
Winnipeg ,MB, MB, Canada
ive tried to find this information for the last week cannot find the size of belt needed for my ac and power steering and the size of belt needed for my alternator and water pump on a 1g plymouth laser rs, correct me if im wrong plz
i tried to find the info and cant so maybe one of you guys can help me out thanks in advance
  • :dsm:
  • :laser:
  • :talon:
Solution
From my old files:
P/S belt: 13x660Li - from the steering section of CAPS
Alt belt: 4PK990 - from the cooling/water pump section
A/C belt: 4PK940 - from the AC section
PS belt 13mm width x 660mm length
Alt, AC belts: 4 is the number of ribs, PK is the cog profile/shape, xxx is the length in mm
Advance's site says:
Alternator/Powersteering:
Cogs:Yes
Drive Belt Angle:38 deg
Drive Belt Depth:0.5 in
Drive Belt Effective Length:26.5 in
Drive Belt Outside Circumference:26.652 in
Drive Belt Top Width:0.526 in
Inside Circumference:25.652 in
A/C and Idler:
Belt Length:37.008 in
Belt Width:0.54 in
Material:EPDM
Rib Quantity:4
Alternator/Waterpump belt:
Belt Length:39.00 in
Belt Width:.54 in
Material:EPDM, Aramid Reinforced
Rib Quantity:4
idk just thought every vehicle was a little diffent[DOUBLEPOST=1412832866][/DOUBLEPOST]
Cogs:Yes
A/C and Idler:
Belt Width:0.54 in
Material:EPDM
Rib Quantity:4
Belt Width:.54 in
Rib Quantity:4
thanks should come in use
From my old files:
Solution
