Bead rolling 101
Gamble97
2,642
63
Jan 3, 2006
small town, Illinois
Well finally after talking about buying something to bead roll pipes I finally bought the kit from harbor freight and used a 20% off coupon, so it was around $150
Benchtop Sheet Metal Fabrication Kit
I bought it because I rolled a friends intercooler pipes and did some welding so it has half paid for itself already. Little upset that I found a really nice bead roller for $300 after I bought and modified this one, but I guess I'll just make this work.
So at first me and my 2 year old go to harbor freight and I asked for this kit and they bring it up and pay for it. I didn't realize how heavy it was. 60 pound! Try carrying that in 1 hand and a kido in the other. It wasn't fun.
Got to open it and the plate on this thing is THICK. So I thought maybe it was a revision, no way a plate this thick can bow like everyone says. I'll measure it, but it has to be at least 1/2" thick.
Put it in the vice (you really need 3 hands with how heavy it is) Put the 1/4" die and start rolling a bead. Well guess what, the piece flexes a lot. So I used some scrap 1/8" thick 1" angle iron. Welded a piece on the top and bottom. I was tired and didin't want to tig it so I tried my 110v hobart handler 140 mig. Eh, the hobart didn't like it. Really needed a beefy machine for it. So I mig welded a few spots and then hooked up the thermal arc 186 in stick mode at 170 amps with some 1/8" rod. Way too much amperage, tried it at 130, still a little hot, and then down to 107 and it was ok. Yes I suck at stick welding. So needless to say my welds on this thing SUCK. But it's holding. I cut a small piece of angle and joined the other 2 pieces, put it in the vice.
And if you crank on it, guess what it, still flexes! The good news is you don't have to go that tight. So I did a practice run and the pipe came out really good. I was happy. Did a few more and not so good. It's really hard to do a piece that isn't 100% straight cut, and it's even harder to do a full UICP that is already welded together. And to make matters worse it won't roll evenly. Your REALLY need a fence/guide. Eastwood sells one, but it's $80.
I stared at this machine for hours and didn't come up with shit. I came up with one design but it didn't work very well and it's hard to do shit since I sold my plasma cutter. I left the house and came back a few hours later with a clear mind. So no plasma cutter and I didn't want to do much cutting so I used the bandsaw to cut up a piece of 12x12 16g into 4 squares (only used 2) then used whatever I had in my scrap bucket.
Came up with this still design.
And here is how my first bead came out with the fence. :thumb: :sneaky: :thumb: :rocks:
Hopefully they all come out like this. But now I'm a few hours into this and $150 loss, I may sell it and get the one I really want.
That setup is great if you also plan on doing some sheet metal work. I'd keep it for because they have a lot of attachments for that style roller. I'm putting money aside for a roller from bead form. Buy once cry once, you can definitely make your money back within a few months depending on your work load
