Battery relocation process
well, that link is done the right way, albeit the very expensive way. im going a different approach. running both neg and positive 4guage(copper welding type) front to back underneath car. roughly 14ft each and mounting behind the rear seat on that little deck. ill let you know how it turns out. using a 660cca battery. ive heard people have success grounding in the trunk but i dont know about that. i can see problems arising. also makes a pump rewire a breese and you can mount an amplifier back there easier too. im doing the relocate tomorrow, ill pm you if it works and try to upload some pics.
use heavily insulated wire if you go underneath the car. im also probably going to spray rhino liner all over it too just for extra security.
I grounded mine in the back without any issues at all on my last DSM
intheory it should work. i may try that first. grind everything down clean up front and in back and see how well it starts, then compare it to my way. just out of curiosity. i sure would like to run just one line rather than 2!
Ground the ground solidly in the engine bay. Ground the ground solidly wherever you relocate it. And by solid I mean bare metal. Bare steel. No paint. Extend only the power feed. Why would you run it under the car when there are built in wire runs on both sides of the interior? That are easy to access. And yes relocating does make it easy to do fuel pump rewire.
Yep Exactly!:thumb:
I know this is for 1g/Galant guys, but I appreciate it for the diagram (because it features pictures).
http://www.dsmtuners.com/forums/art.../426604-1g-galant-vr4-battery-relocation.html
In terms of actually doing the relocation, really, you can just take the positive terminal of the battery, unscrew it, cut all the wires (from the fusebox and starter), put it in a power distributor block, grab a 0 gauge 12ft long-ish cable, run it to the trunk, and ground it (which is exactly what I did). However, this is the <b><u>WRONG AND IMPROPER</b></u> way to do it as it will <u>NEVER</u> pass NHRA rules (which I believe the battery must be tied down, in a vented box, with a kill switch).
Everyone will tell you to SEARCH, as there are indeed many threads on this already.
I'll just be nice and link to a post that I believe is one of the most helpful examples of how to relocate the battery to the truck properly.
http://www.dsmtuners.com/forums/152022910-post471.html
Good Luck!
Much appreciated. I could have just used the search button but I prefer to put up a post and get feedback from people who have done it. I'm also trying to network more on this site. Thanks again!
i ran 4guage one way and grounded the neg to a bolt in the trunk. works BETTER now! cant believe it. also, i saw the track by the door and used that, waaay easier and looks better. putting it underneath would have been dumb
that was my original concern. keeping the fire out of the passenger(cabin) compartment. but when you look rneath the car at all the rock chips and scrapes, you quickly realize if you run it there, it will eventually break down. it was the lesser of 2 evils. and no, LOL, i dont think im going to have a cabin fire with my set up. ill let you know if i do though.
The search function has this nifty feature where you can find threads where people have actually done it as well. Comes in handy :thumb:
Around here taking the time and effort to find your own answers is respected quite a bit more then expecting to be spoon fed.
That is a pretty nifty feature! I would have never guessed! Thanks for the insight. :thumb:
well i gotta eat my words. now if the car is warmed up and i shut it off and go to restart it, wont crank fast. ive got a ground problem somewhere i think(hope like hell). if not, looks like 2guage wire is in the budget. the block to firewall connection is 15yrs old and looks terrible so im going to start there. resistance is good everywhere but as you know, with higher load you get higher resistance.
so when you do a battery relocation all you have to do is exstend the positive battery wire to where your relocating and reground it in the trunk?
Not if you plan on passing a tech inspection at a track. Also, if that positive cable gets crimped/pinched and shorts out to your chassis it can and will start an electrical fire somewhere.
