battery drain
wishful_laser
242
Nov 25, 2003
springtown, Texas
I moticed the other day that my driver side window would still go up and down without my key in ignition. Its weird but its draining my battery. Im not sure exaxtly where to start looking to solve my problem. Guess i could pull window fuse out but then they wouldnt work at all
Is the window the only thing that works without the keys? Also do the interior lights go out? If not then it could be the door switch... But the window situation is weird. Never heard anything of the sort.
My door open interior light does not come on when on that switch but it will come on when i turn. It on. Far as i know jist the window is jacked. Also the other interior lighrs dont work either. Ill check fuses see if i find anything.
