base timing 2.5 degree.
Nikolay_Ruskov
231
3
Jan 25, 2008
san antonio, Texas
Hi my base timing is 2.5 degree is this normal ? I ground the timing connector to ECU with v3 link .My idle its 750rpm and I don’t have any boost leaks.I know its should be 5 degree but its also say that’s its +-3degree.And my car is 2g 97 and I think I cant fix it whit crank angle sensor.
Yes i use a timing light.
The crank pulley look fine.
Do i have to take out the timing belt and do it over again?
I got hks adj.cam gears can i fixed from over there?
