2G Ball joints
LOL yeah. Well there might be some slight difference between the 2.
I would say just log on to rock auto and match up the part numbers and chech which one is meant to be for which side. there might be some minor differences that are hard to tell just by looking.
You aren't looking in the right place. It is just a slight difference, but they are different. If they were the same part they would have the same part number.
Didn't the OP say that these were not OE (in Post #7)? What is slightly different about the OE pieces might not have been copied.
Correct, the cup angle is points in the opposite direction on the 2 joints. You have to lay them flat on a table and look at them from parallel with the arm.
Your pictures are not (at all) convincing to me. The bottom of the lower shock mount and the bottom of the inboard pick-up point are not flat, and you have them both tilted to the same side on the table. Pictures with one tilted each direction would be more useful. Better yet, make it so that the inboard pick-up is square to the table in both cases and then photograph the ball-joint. Then we could really see whether they are different.
