Balance shaft
awdturbo-g1
70
Apr 4, 2010
st.peters, Missouri
Im putting a new timing belt on my car because it jumped time on me and I was wandering were I can buy a removal kit for the balance shaft? Also when my car jumped time it bent a few valves and should I Chang the valves or get a new head? Thanks agen everyone.
You can get BSEK's from pretty much anywhere. MAPerformance, Extremepsi, Buschur Racing, etc.
As for the head, a machine shop will need to determine if you need a new head or not but at the least your valve guieds probably cracked so those will have to be replaced.
Dang do I have a chance of the valve gides not being crack? It barely even bend
Sure, there is always a chance they aren't cracked. You machine shop will need to tell you if they are or not but with most things in life I expect the worst and hope for the best. So I would count on them being cracked and then be joyous and have a party if they tell you they are not.
You might as well rebuild the head with new seals and if you want, stronger/stiffer springs for the future if you plan on revving out.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
