balance shaft
Your going to feel more vibration then before, because the timing belt is still spinning the other balance shaft.
Other then that will it hurt anything. I have a guy working on it and he just found out the gear on the BS was just turning with out turning the BS
I say remove it i just hade mine removed cant really even notice its gone. And guy from one the the dsm shops i called around here said its best to have it removed cause the bearing will freeze up at sometime if you dont replace them
Balance shafts are harder on bearings than rods or crankshafts. Either remove the shafts or replace their bearings.
No shafts will vibrate but no problem.
New balance shaft bearings will cost time and money but otherwise no problem.
Old worn bearings on high mileage engines... problem. Expensive problem.
Maintain or remove.
Thanks Guys. I'll just take them out. I'm assuming both. Can this be done without removing the engine?? How much vibration are we talking about?? And last but not least, will the oil pump be safe?? Thanks, Josh
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
  • For sale 1g 1990 Turbo Throttle Body ( rebuilt )
    1990 Turbo Throttle Body $85 shipping & paypal fees* this throttle has been rebuilt and is in...
