2G Balance Shaft
95TSi_NC
31
Aug 25, 2005
Charlotte, North Carolina
Has anyone noticed a vibration in the engine when you take out the balancing shaft?
When I was driving my car and let off the gas theres a vibration that travels from the front to the rear of the car. Its not the drive shaft and differential.
Help.
:talon:
Help.
:talon:
A slight vibration is normal. Search and you shall see.
Please note that there are two balance shafts in the engine.
The upper one is in the front and driven off the balance shaft belt. The lower one is in the rear and is part of the oil pump driven off the timing belt.
Both should be eliminated at the same time.
Steve
