dsmputz
- 130
- 2
- Mar 26, 2006
Saskatoon,
Allright guys I am sorry to bring another BS question to the table but I need to shed some light on a subject. I bought a brand new oem front case with the bs elimination kit. The kit comes with two bearings, the stubby shaft, and a cap. I knocked the one bearing with the oiling hole out of the block and replaced it with one that came in the kit. Then I pulled the seal out of the front case that was for the balance shaft and jb welded the cap in all pretty.
Next I put the stubby shaft in with permanent loc-tite and torqued to 30 ft lbs. Anyway I'm sure I completed the removal correctly but I have one bearing left over in the kit, where the hell does it go? It is smaller than the one used to block the oil hole. It's a 1G 6 bolt if that matters.
thanks again
thanks again
