balance shaft removal
Status
Not open for further replies.
motoman358
189
3
Jul 29, 2005
Oak Creek, Wisconsin
where is the best place to get the parts for the balance shaft removal? i have been lookin on ebay and there are a few different kits with different numbers of parts and im confused as to why some kits have more parts than others.
Dealership -
stubby shaft: MD098626
block off plug: MD092785
Front bearing: MD040597
Rear bearing: MD103722
Slowboy Racing -
stubby shaft
full BSE kit
The cheapest way is to just buy the stubby shaft (~$12) and pull the rear (oil pump) shaft off and replace it with the stubby shaft. Then just cut the belt for the front shaft and put washers on the back side of the front balance shaft sprocket and tighten it down so it doesn't move.
Otherwise you have to punch out the front 2 bearings and punch in the new ones so the oil holes don't line up.
Either way blocks enough of oil flow to the shaft. I've done both ways and both cars are running fine with higher oil pressure.
Status
