Balance shaft delete question
too_genecide
82
10
Jan 26, 2013
yuma, Arizona
This may have been covered already and if so I must have missed it in my search.
I would like to know the cons to cutting the stock rear balance shaft just aft of the oil pump. I know that there is an oem solution to the rear shaft delete.
Why not?
Like Pauly said the stock balance shaft has a bore in it and that is where the bearing on the oil pump side shaft gets it's lubrication. You can cut it and weld it but i would advise against it. Just get a OEM stub shaft and be done with it. Alternatively you can turn down the stock shaft and run it to help support the oil pump gear. I find it not necessary but some do.
