bad valve check?
775TSI
148
Nov 8, 2009
Carson City, Nevada
Is there a way to check with the valve cover off to see if i have a bad or floating valve? I did a pressure test with a gauge and vacuum line and it flutters pretty bad. I used the vacuum port at the top driver side of the intake manifold. I had 13 psi coming from that spot but it bounced up and down a lot. I have had suspicion that i might have a bad intake valve so i ask is there a way to check my valves with the valve cover off before i remove the head?
Are you sure you don't have a boost leak in that area? Quite a few places that could be leaking that pressure giving an inconsistent reading.
With a vaccume gague hooked up at the Intake @idle, NO boost
Check to see if the needle is steady, if so valve seating should be fine in the head
If the needle jumps around, then there is a valve seat issue, IE: bent or burnt valve
No real way to check for valve float, on the car.
The valve springs maybe weak if they are the factory installed springs
