Valve Tap = Bad?
It sounds like that is actually the hydraulic lifters, not valve tap. Valve tap is when the pistons are hitting the valves, while this would be from there not being enough pressure in the lifters and the rockers are tapping around. This is completely normal and happens on nearly every DSM that has not upgraded to the 3g lifters. There are several remedies if it gets really bad, but it really is nothing more than an annoyance.
valve tap is actually the cam lobes hitting the lifters, try getting a valve adjustment or get a hanes manual and look up the valve lash for your motor and adjust them yourself. its not a bad thing just an annoying noise.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
