Bad turbo. How much for a rebuild?
teampruven01
41
Dec 30, 2011
slippery rock, Pennsylvania
Is it more cost effective to get a turbo rebuilt? Im blowing oil bad. Guessing its seals. Has anyone paid to have thos done? How much is it?
Turbo rebuild kits are around $100. The actual process is straight forward. There are also guides out there on how to do it. If you wish for it to be professionally rebuilt, then contact Justin on the forums. Jusmx141
I've always rebuilt mitsu turbos myself via the vfaq. Its easy and theres a kit on ebay for $45 shipped that works great. Just have to make sure you scribe the line across the shaft, nut and wheel. This is the one I've been using: http://www.ebay.com/itm/Performance...pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr
Obviously as long as the turbine wheels and shaft are ok rebuild kits for most turbos are cheap and wouldn't require a rebalance unless you wanted to have it rebalanced just in case.
I've always rebuilt mitsu turbos myself via the vfaq. Its easy and theres a kit on ebay for $45 shipped that works great. Just have to make sure you scribe the line across the shaft, nut and wheel. This is the one I've been using: Performance TD05 TD06 12A 12B 14A 14B Turbo Repair Kit | eBay
I just watched a video on it. I dont think its something i wanna get into
i think i'm just going to buy a new big 16g setup. anyone buy used turbo's? what would this small 16g that needs rebuilt be worth?
No offense but whos to say what "quality" is? You can't say one is over another unless you get both and have them tested one against another, I've not had an issue with what you'd call "cheap" parts but everyone is different. Regardless each is to there own and Pruven doesn't want to rebuild it anyways, going to have someone else do it.
OK, you're right. I mean I prefer OEM materials. Sorry.
