ECMlink bad maf?
907talon1G
Sep 25, 2018
Chugiak, Alaska
Curious if this log's MAFRaw value seems erratic. The HZ will jump from 20-175 hz just at idle alone. Most logs I've seen have a much smoother log for their MAFRaw at around 40-50HZ +-10% You can also see in the log that I held 2000 rpm but the MAFRaw value didnt change much at all from idle.
This is a stock 1g maf. I have no boost leaks or pre-turbo intake leaks.
The car sputters at idle and lower rpms like a misfire and wondering if the maf is something that I need to address.
