General Bad Maf?
lasershark
1,607
237
May 17, 2013
over yander, Idaho
Finally got the car started, idled like crap did a log to find out I am not getting any metering air. It reads 0 gms/sec does this mean the maf is toast? also getting a P0100 Volume Air Flow circuit.
I am new to link and watching/reading a lot but need a little help on this one. What do I need to test? or is a setting wrong in link?
thanks
MAS or the wiring. Test for continuity from the pins on the MAS connector to the pins on the ECU harness side connector. Your connector(s) might be shot; check the contacts for broken tabs.
