bad idle
What I mean by bad idle is sometimes it will idle around 900 and other times it will go between 100 to 300. I can post a video right now cause the only internet I have is on my phone
Have you did research on upgraded cams something else is going on, then, i would go back to stock simplest solution it seems.
Its kinda rough to diagnose without a tuning device. The ecu is going to have a rough time recoginozing and compensating for the situation. I would do a BLT and go from there. If the problem still persist I would go back to stock cams until you have a way to tune.
