bad idle solved
slowboy101
285
Nov 26, 2009
Lakeville, Minnesota
Ok so here is how I solved my idle surge. When I started to mod my car my idle started to get bad for instence it would jump up and down and even some times die. So here is how I fixed it, I simply took out my battery for a few hours then put the battery back in, got in the car turned my a/c on full blast and then started the car and BLAMO idle surge solved. Now im not saying this will work for every ones situation BUT after you checked for all boost leaks and ect. then try this! :hellyeah:
LoL, lucky. Probally was fine until an adjustment in your BISS or timing was done without grounding out the right stuff. So your ECU was trying to compensate. Resetting your ECU reset it's ability to control Idle and now it's in the zone.
With increases or decrease's in air/fuel intake your idle will fluctuate doing this will throw out of whack the ability of your car's mechanics to control the idle. Resetting the ECU makes it learn from scratch putting all the adjustment mechanics back to neutral, when before they may already be at a maximum/minimum setting.
  • For sale 2g NOS Sebring/Avenger floor mats
    These are slightly different shape than 2G mats but very close. NOS and still in plastic wrap. I...
    • MindBlowin03
  • Wanted 2g Anyone parting out a 2G?
    Need a few bolts that I'm missing for the rebuild, subframe and crossmember specific. Anyone...
    • Mahreeoh17
  • For sale 4G63 Mitsubishi # 284K00708 tach filter
    Mitsubishi OEM tach filter. With weather pack connector. Message 702-741-6987.
  • For sale 1g NEW ETS Street Intercooler for 1G DSM ( 4” Core )
    NEW ETS Street Intercooler for 1G DSM ( 4” Core ) $475 + shipping & paypal fees* these are...
  • For sale 2g 2g power window motors. OEM
    2g RH and LH power window motors OEM, $30 each. Sold the drivers and pass set of door switches...
