Bad fuel leak injector o ring (in the head)
brandonzero0
376
Sep 1, 2005
Detroit, Michigan
Is there different Type of O ring for after market fuel injectors? the stock ones always seemed to fit tight and now that my car runs I would like to fix this, Thanks in advance.
Not that I'm aware of, as long as you ordered the right type of injectors it should seal up fine. If not the seal has probably just gotten too old and repeated heat cycles has left it dried out and rotted.
There's only 2 major styles that are common on cars in america, one type is what is most commonly used on imports and then the other is common on cars by the "Big 3" and are different. The differences are hard to explain, but i have both on hand if you end up wanting a picture of what is correct and then the other type next to it let me know.
My FIC 650 injectors need different seals than stock. What do you have?
Yes, I picture would be great.
okay, I will get one after i shower and run my errands for hte after noon.
