konigtalon
- 40
- 0
- Jan 5, 2006
morehead,
Kentucky
Hey there guys I just purchased Two Turbo DSM's a 90 GSX and a 91 TSI. We'll the gsx is mine and I did a compression check and come up with the following results 160 in every cylinder but the third one which was 40
. We'll my question is this if what do u all think would cause this I'm leaning towards the rings being bad haven't done a wet test yet. Also when I attempt to do this I just want to make sure I got everything correct. To begin I remove the timing belt, take the head off, remove the pan and unbolt the rods from the crankshaft then check the cylinder to see if it's hurt bad if not then I can do a rehone put the piston and rings in bolt everything back up and be done right? Also how do I line the piston ring's up? They are already on the piston any help would be greatly appreciated IM attemptinmg this this weekend. Thanks, Dewayne
