Back fire at high rpms under Boost.
Sicotic
278
May 26, 2009
fairbanks, Alaska
Once agian another question searched but didnt really get a answer. Back to my situation i was driving decided to hit throttle to the floor and about 5k-6k my car backfired like crazy and it fell on its face, but then it drove like normal. It did it a few times at high rpms here some conclusions
1. Black plugs(Running Rich)
2. The flex pipe is broke into 2 sounds like crap.
3. How do i check my coilpack?
4. I did a BLT with soap and water nothing, how can i check the BOV?
Can someone point me in a direction.
Those are classic boost lead symptoms.
Did you test around the throttle body shaft seals in the BLT?
I had that symptom recently and it was cured with a new throttle body.
i checked a boost leak but didnt find nothing i did it with soap and water tho/.
ya the guy before said it was set at 14 psi on stock guage, the other day i hooked up a boost guage it it was like at 25 psi but i thought it was just a bad vac to hook up so ignored, it bc when i start in first gear my car would almost go sideways, but now that i think about it i bought a 14b turbo from a guy that had a VR4. ill go take a vid real quick.
i have a boost guage just not hooked up, no controller, just hooked up my boost guage and it was at 15psi of boost
