Back camber
Use the longest one that will work with the number of washers you end up using yet won't bottom out when tightened. As I recall 30mm works with 3 washers, 40mm for more. Too short and not enough threads will engage so it can (and did on me) pop out and damage the threads. Too long and it will bottom out causing the bracket to not get tight.
When you drop your car is always going to have that negative camber increase due to the suspension not sitting properly, best thing to would be adjust the toe and roll it or if you are just anti stance then buy a camber kit and take it to a shop with a legit ass alignment machine, the one my shop just got allows us to enter in custom specs for modded vehicles that compensates for the drop
I wasn't aware that not all professional alignments were created equal. What kind of machine/process should I ask around for in my area if I want to get an alignment for my dropped car with modded suspension?
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
