axle out of kunckle - hub still attached?! Help
VPrime
802
3
Feb 5, 2006
Lonon, ON, Canada
can you get the axle out of the knuckle with the hub still attached to the axle?
Axle froze up in hub? Axle comes out of the back and hub is pressed out of the front.
No, no way to do it. If you are trying to pull the tranny, you can remove the axle and spindle as an assembly. If you are trying to replace just an axle or spindle, they need to be separated. This may involve a press, torch, big hammer, or all three.
Sorry for the caps lock, my finger bumped it.
