Axle clip stuck in trans?
GSLENK
1,416
56
May 25, 2011
DC, Maryland
TL;DR -- I suspect there is a transaxle retainer circlip stuck in the female part of my trans and it is preventing the new axle from snapping into place. Is this possible and is it easy to remove/fish out? This is for the passenger side axle in a 1gb AWD 5-speed DSM.
More story:
I swapped axles recently and drove the car a bit then a few days later a little trans oil was in my parking spot. The leak was from the CV axle seal. I checked and the axle was able to slide around so I figured I must not have pounded it in hard enough to get it to clip in. Took off the wheel and tried to pound it again. No dice still slides out a little. I pounded pretty damn hard too, Hope I didn't mess anything up. Is it possible to press the axle in too far by the way?
Frustrated, I put it back together and called it a night. Then I thought, maybe the old clip never came out and is messing me up. Sure enough, the removed old OEM axle clip is not on the old OEM axle that was replaced. I know it had a clip before because I had to really pry to get it out of the trans. So has this happened to anyone? Is a clip easy to get out of the trans? (is there another groove where the axle slides into for the clip to catch or is it floating around in there?)
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
